4/25/2013 12:25 PM | |
Posts: 215 Rating:
Hello acik, I would propose a second solution: You should decide betweenthe aspects of costs and efforts: First solution: you could use analog modems, which I assume to be a cheap solution but you have to bare the effortto install and test. Second solution: you replace the LOGO! 0BA6 by a LOGO! 0BA7 connected via Ethernet to your PC, which I assume to be an expensive solution with less effort. The advantage of using Ethernet is to get the option to expand easily the configuration with up to 7 LOGO! slaves. Information about maximum length of ethernet cable is to be found here http://en.wikipedia.org/wiki/Category_6_cable Does this help as well? |
