9/7/2010 5:24 PM | |
Posts: 32 Rating:
Hi Expert , Good afternoon expert Lifrasil, Helmut_13, Betel, LOGO!Barbarian and everybody in this forum. I have make a circuit for regenerative control to share with your and need some advise for control circuit improvement. Hopefully there will be reply from you all. Best regard, liew nelson AttachmentCAP & RESISTANCE BANK IN SEQUENCE.zip (281 Downloads) |
9/8/2010 11:44 AM | |
Posts: 173 Rating:
I 'think' I can see what you are doing, but I am not too sure if you hav a problem with this circuit or not - please tell us what is not working the way you want it !??!?! Otherwise, my suggestion would be to use a shift register moving a single bit along and resetting after the 3rd capacitor bank so that the first can be recharged again. This would be more 'elegant' and a bit more understandable (and also easily expandable!). Have a look at the tips and tricks under the LOGO! web page www.siemens.com/logo under the Application Examples link.There is a good example there of how the Shift Register works (if the on-line help file does not explain the block clearly enough. Otherwise, we will look out for your next post of what you want to change! Cheers |
