9/9/2022 6:36 PM | |
Joined: 2/10/2022 Last visit: 5/28/2024 Posts: 3 Rating: (0) |
Hi! My problem is that after several changes in the project, when opening it the "Home Page" does not show in the Logo! Web Editor, however when opening the directory where the project is saved the main.html file is there and complete. How to solve this?
Attachmentlwe.zip (304 Downloads) |
9/9/2022 7:02 PM | |
ok, attached the project The LWE version is 1.1.0 thanks AttachmentLubrificacao_Auto2.zip (402 Downloads) |
9/9/2022 7:22 PM | |
Joined: 12/18/2014 Last visit: 6/1/2024 Posts: 33138 Rating: (4094)
I think your project is damaged. Start a Support Request and share the project with Siemens. |
9/9/2022 7:27 PM | |
Thanks. |
9/12/2022 7:10 AM | |
Joined: 9/19/2018 Last visit: 5/31/2024 Posts: 382 Rating: (46)
I tested your LWE project and have to agree the project is defect. As only development can repair defect project we need a Support Request for this. As there are improvements in the actual LWE V1.1.1, I recommend to update: https://support.industry.siemens.com/cs/ww/en/view/109811402 Hint: You have to uninstall the “old” LWE version before, because only one version of LWE is possible on a PC. If you are not yet registered, the registration must be carried out beforehand because the software is restricted to export. When registering, the check mark must be set for "Access authorization for downloading export-restricted software", see: https://support.industry.siemens.com/cs/ww/en/view/109744535 |
