11/22/2020 12:41 PM | |
Joined: 9/27/2006 Last visit: 4/27/2024 Posts: 12257 Rating: (2665) |
Hello saleh; Based on this document from PI (Profibus International) a Profinet network will work well with unmanaged switches, as long as you do not require sprcializef protocols such as SNMP and LLDP. In this case, a managed switch will be required. And if you are running a Profinet installation with motion control (Profinet IRT) you will definitely need a managed switch: //us.profinet.com/managed-unmanaged-switch-profinet/ To select among the offerings of Scalance X switches, study this Siemens presentation: Brochure: Industrial Ethernet switches - Scalance X Hope this helps, |
11/25/2020 3:17 PM | |
Posts: 6 Rating: (0) |
Thank You, that information was helpful. I also found some tips in page-29 of the following document: |
