4/28/2016 6:52 AM | |
Joined: 4/28/2016 Last visit: 10/3/2023 Posts: 18 Rating: (0) |
Hi to All Dear Friends i need help from you, i want to control lighting system of our plant facility by using plc. i want light should automatically on at about 6pm and should automatically off at about 6am morning. i want to do by using interrupt. i have read about OB10,SFC28 but have some confusion. manual not clear or may be i do not understand properly. please guide me. thanks in advance. Asif Iqbal ------------------------------------------------------------------------------------------ |
Last edited by: The Helping Hand at: 4/28/2016 10:06:22 AMNew subject after splitting |
4/28/2016 7:13 AM | |
Joined: 10/2/2013 Last visit: 5/15/2024 Posts: 339 Rating: (52) |
First of all you should create new task, You may use SFC1 for your work,refer SFC1 help for more details. https://support.industry.siemens.com/tf/ww/en/postattachments/download/?attachmentId=3877 |
Last edited by: ANKURGAMIT at: 4/28/2016 7:15:30 AMTechnology is best when it brings people together,so we are here now :) |
Joined: 1/28/2012 Last visit: 9/15/2023 Posts: 519 Rating: (83) |
You may use "SFC1" (READ_CLK) can be used. Simply compare time & fulfill your logic requirement. OB10-17 can be triggered on particular time & it will be called only once. For more info attaching help file from "Step-7 offline help". I hope, it might needful to you. Attachments7.pdf (293 Downloads) |
Regards, |
