5/8/2017 6:16 AM | |
Joined: 1/17/2013 Last visit: 10/16/2024 Posts: 1106 Rating: (7) |
Do you have manual of PLC S7-300 connect with DCM by profinet or profibus ? How can it (DCM) control by PLC ? Thank you ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 5/9/2017 10:56:21 AMNew subject after splitting Best Regards, |
5/9/2017 11:09 AM | |
Joined: 10/11/2006 Last visit: 11/6/2024 Posts: 5934 Rating: (815)
Hello, the DCM supports standard telegrams (e.g. standard telegram 1). You connect the drive via GSD file to your PLC in the hardware configuration. Here you find PROFIBUS and PROFINET GSD files for the DCM: https://support.industry.siemens.com/cs/ww/en/view/98206128 https://support.industry.siemens.com/cs/ww/en/view/98207877 You could program the cyclic communication with SFC14/15 for example. |
With best regards, |
