5/26/2010 2:51 PM | |
Posts: 7 Rating:
[thank for reply, we check the IGBT again tofay,I send the advance, Why when we disconnecrt to diffrente Fiber optic, continue to appear the F027 |
5/27/2010 7:38 AM | |
Joined: 7/8/2009 Last visit: 7/26/2023 Posts: 1974 Rating:
As Grame said earlier too, Most chances for this fault in your case is SSB Board (K80 Option) According to Manual, If Safe Stop is operated when drive is in run mode, or you make drive in run mode before safe stop removed, You can get this fault. It is not necessary that you will get F026 or 25 along with F027 Check out attached file. AttachmentSafestop.pdf (1847 Downloads) |
I dont Like people driving Fast, thats the reason I overtake them ;) |
5/27/2010 3:09 PM | |
Posts: 7 Rating:
Dear Vithani: thank for your reply, what happened if dissable the safe stop? only for test. |
