2/6/2016 12:19 PM | |
Posts: 1 Rating: (0) |
Hello Everyone , In one of my machine , I am using siemens servo motor with MC drive . It's been a repeated issue in the drive that motor is vibrating but no fault code coming in drive. In past one year I have changed 4 drives. Motor , cable also i have replaced with new one. Some times if i do power restart , after that motor is running fine. But after some time motor is vibrating. Replacing the DRIVE solves the problem every time . What component might have failed inside ? Please let me know what will be the problem ? drive used is 6SE7022-7EP50-Z. ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 2/8/2016 4:25:10 PMNew subject after splitting |
