5/30/2013 4:25 PM | |
Posts: 24 Rating: (0) |
Dear Fletcher hope you are good just wondering if your trolley encoder cable is going in Energy chain or festoon system also if your system is using a DTI card or not. most likely from our experience the problem for 90% of the time is DTI Card as we use robust type of encoders the energy chain cable maybe defected due to cable friction with each other and with the chain itself normaly replacing the DTI card it our 1st step than we replace motor encoder and check the cable in the chain. hope you find this helpful Regards, Muhammad Saleh |
