2/27/2016 10:02 PM | |
Joined: 11/29/2011 Last visit: 9/26/2024 Posts: 1359 Rating: (232) |
Hi, Maybe you should try to rethink/restructure your application. In the compendium bellow you find guide for this. (See the manual SIMATIC Process Control System PCS 7 Compendium Part B - Process Safety (V8.1) chapter "5.1.3 Cyclic interrupts ")
I hope I could help! |
Last edited by: MicroMan at: 2/29/2016 9:46:55 AM- What you read here, please check with manuals and your requirements. |
9/9/2016 5:55 AM | |
Posts: 30 Rating: (0) |
Exactly same problem I am facing. Is their any solution for that???? Thanks |
9/9/2016 7:16 AM | |
Joined: 3/14/2008 Last visit: 10/15/2024 Posts: 2111 Rating: (942)
Hello guys, You can follow the steps in the document I enclosed. Let me know if that is the solution! AttachmentHow do you clear the message Maximum code length of code area reached.pdf (957 Downloads) |
9/10/2016 5:46 PM | |
Hi Please refer the attached error snap. Thanks |
9/10/2016 11:57 PM | |
Hi, It is hard to say from the limited info we know about your code, but It sounds like that too many "F-Module drivers" is being generated in one Runtime Group. See SIMATIC Industrial Software S7 F/FH Systems - Configuring and Programming manual under chapter "6.2 Generating F-Module drivers" Have you considered to split the code into more F-Shutdown groups? I hope I could help! |
Last edited by: MicroMan at: 9/11/2016 11:30:52 AM- What you read here, please check with manuals and your requirements. |
1/17/2018 4:04 PM | |
Joined: 3/2/2007 Last visit: 10/16/2024 Posts: 938 Rating: (5) |
Kindly how did you solve this problem ? " Maximum length of code area reached (max. 64 Kbytes) "
... thank you ... |
