4/10/2024 11:07 AM | |
Joined: 5/30/2022 Last visit: 5/17/2024 Posts: 524 Rating: (86) |
Hi jthyge1, It does not specify a maximum number of PLCs that can be integrated into a TIA Portal project. The manual also does not state any limitations: SIMATIC STEP 7 Basic/Professional V19 and SIMATIC WinCC V19 I would recommend checking the necessary hardware and software resources for the installation of the TIA Portal. Perhaps balancing the number of devices in different projects might be better.
If this information really helps, you could use the Rate function. |
