2/27/2012 6:46 AM | |
Posts: 31 Rating: (2) |
Dear All we are facing a problem in MasterDrive Mc F61 the drive wasworking then suddenly showing F061. the simolation is ok the power block is ok we have factory reset the drive and it was working normal with ASM motor with out encoder but when put the drive with orignal parameters it shows F61 the new drive (hardware) is working normal under same parameters. Please let us know what could be the problem Parameter file is attached Thanks Best Regards Attachmentnew ok 22-02-12 waqas.zip (517 Downloads) |
2/28/2012 6:02 AM | |
Dear Graeme Thanks for ur reply iwill surely do this and let you know Thanks again Best Regards RK |
