2/1/2023 7:11 AM | |
Joined: 1/24/2021 Last visit: 6/1/2023 Posts: 120 Rating:
Seems that your spindle hasnt been referenced. Why? Maybe encoder/cable is faulty, but if that case alarm should be appeared. I think you have belt driven spindle on your machine, check if the belt is broken. What type of encoders are used on your spindle? Also check PLC variables DB36.DBX1.5 and DB36.DBX1.6, instruction is attached. Attachmentplc_var.pdf (84 Downloads) |
