11/26/2019 5:54 PM | |
Posts: 2 Rating: (0) |
Hi I have problem. I replace the CPU S7-400 old version to new version, then I upgrade at Hardware configuration the model and I down load. then I have an error at diagnosis buffer please refer the attachment picture. the same time i compare the program and found some FB,FC and DB missing. then i download the missing block but i couldn't load an error appears the memory unnsafience. I try many time but same error occurred. I try reset and load again but same problem. then I change back the old CPU and insert the CF card. reload the program. Please advice me what is the error and how I can replace the CPU. Thank you ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/27/2019 10:15:54New subject after splitting |
11/27/2019 10:16 AM | |
Joined: 6/19/2017 Last visit: 4/26/2024 Posts: 7952 Rating: (162) |
Best regards Jen_Moderator |
