7/23/2015 3:15 AM | |
Posts: 1 Rating: (0) |
Cant anybody tell me why I am getting this error: Can not install kernel.ex_. Directory or filename might be incorrect. I tried editing it to kernel.exe. Still the same error. This is V4.0. I already installed chinese language pack maybe that will help but still the issue persist. I am installing it to Win Xp Sp3. I am trying to install the software
Last edited by: Min_Moderator at: 7/23/2015 10:09:12 AMNew subject after splitting |
7/24/2015 10:13 AM | |
Joined: 7/9/2015 Last visit: 11/19/2024 Posts: 4028 Rating: (603) |
Hi, I think you have a problem with the compatibility. If you use XP Home 32Bit SP3 or XP Prof 32Bit SP3 you need Micro Win V4.0 SP7 or higher. Look here, I hope it helps you! https://support.industry.siemens.com/cs/de/en/view/58523240
