3/6/2020 2:32 PM | |
Joined: 7/5/2006 Last visit: 2/13/2024 Posts: 177 Rating: (4) |
Hi, i've made a migration of a project from Wincc flexible to TIA Portal V13 and then to V15sp1. When the migration is finished, i don't have any errors, but the graphics property of many images are changed. In the attached files, it's possible to see that the graphic image after the migration has the transparency box checked, but the image is not transparent. It's necessary remove the checked to activate the transparency. That's it. best regards Attachmentfrom_migration.pdf (31 Downloads) |
Last edited by: walter_g at: 03/06/2020 14:32:57Last edited by: walter_g at: 03/06/2020 14:33:48 |
3/12/2020 10:39 AM | |
Joined: 8/3/2009 Last visit: 5/17/2024 Posts: 12970 Rating: (1651)
Hello Walter here is the answer to your question: https://support.industry.siemens.com/cs/ww/en/view/101167295 (dont forget to rate if this is the solutio nfor your Task thx) Bye Murof |
