3/6/2009 6:59 AM | |
Joined: 3/21/2006 Last visit: 11/1/2024 Posts: 10229 Rating: (1181) |
Hello You can look at manual COM PROFIBUS (from page 32). There have example how to enter parameter in ET200M slave, regards digital and analog cards. . Be caraful, with changing type of analog cards (inputs and outputs) and specially their range, you'll need to change devices which you read/control. Hope this will helps. regards |
3/6/2009 3:42 PM | |
Hello So, let's continue with COM Profibus 3.3.. Look at ET 200 Distributed I/O System (from page 329). There you'll see example how to set ET200M to the master parofibus. Yes, you are right, the way is a little different from v5.0 Hope this time you will have success. Let me know the result. regards |
3/13/2009 6:31 PM | |
Hello Would you try this way: Importing / reading COM PROFIBUS V.3.x files with COM PROFIBUS V5.0. regards |
