6/26/2009 5:34 PM | |
Posts: 19 Rating: (1) |
I have a request, can someone write example to determine min and max value from DB ? Data types: REAL. I will grateful for any responds. Regards Mat84 |
6/26/2009 5:57 PM | |
Joined: 1/4/2008 Last visit: 6/19/2024 Posts: 703 Rating: (96) |
Hello, I just copy here our PMs, don't have time to do it myself, but maybe it will help somebody...
6/26/2009 6:56 PM | |
ok, I find a solution, and it is work |
11/27/2013 9:43 AM | |
Posts: 10 Rating: (0) |
Hi, Can you post your code on? Thank you Bach |
2/4/2014 2:31 AM | |
Posts: 17 Rating: (0) |
Dear Sir, Could you please tell the solution as i am having the question |
2/4/2014 9:52 AM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (714)
Hello, You can use bubble sort to sort your DB: Sample program for sorting a data block Then you know where the highest and lowest number is located. If you want to keep the original DB, Block move to a new DB first. Regards, Marcjan |
Problem solved? |
2/4/2014 11:40 PM | |
Thanks mate, it is working
