9/29/2012 3:11 PM | |
Joined: 6/4/2008 Last visit: 4/23/2024 Posts: 1481 Rating: (322)
Direct Answer - Read the manual See extract attached. You have two choices seeing as you don't want to use Dynamic braking. You can use DC or Compound braking. The parameters are listed at the front of each section. You cannot expect anywhere near the performance of Dynamic braking using either DC or Compound. Regards, Graeme
AttachmentPages from Operating Instructions.pdf (683 Downloads) |
10/3/2012 7:44 PM | |
Posts: 10 Rating: (0) |
I dont have resistor ready in stock. Ok graeme, I will connect resistor and come back to u. Thank u for your valuable suggestions.
