5/20/2019 7:09 AM | |
Joined: 4/28/2015 Last visit: 6/28/2024 Posts: 578 Rating:
This node, just like node-red-node-serialport, pulls in a native binding for the accessing the UART. This binding needs to be recompiled for the Quark. You can do that by appending "--build-from-source" to the "npm install" command. To make life easier, we will pre-package this node in the next image release (https://github.com/siemens/meta-iot2000/pull/124). |
5/20/2019 10:49 AM | |
Posts: 24 Rating:
Thanks for your reply, Please can you tell me how to write the "--build-from-source" command ? is it like this ? cd /usr/lib/node_modules --build-from-source |
5/20/2019 2:26 PM | |
Posts: 24 Rating:
Well, I tried this, but it did not work. I made a fresh installation of the image, then, I first runned that command before autostarting node-red. maybe because of this error : "gyp WARN EACCES user "root" does not have permission to access the dev dir "/home/root/.node-gyp/6.12.3" Please find in attachment the log file. Attachmentinstallation log.txt (404 Downloads) |
5/21/2019 10:13 AM | |
Joined: 12/12/2016 Last visit: 4/8/2024 Posts: 640 Rating:
Hello, Can you please share the flow so we can exclude the possibilty of a faulty config? Kind regards! |
5/22/2019 12:12 PM | |
Posts: 24 Rating:
Hey guys ! any news ? I am out of ideas. |
5/23/2019 2:41 PM | |
Posts: 24 Rating:
IT WORKED !!! THANK YOU VERY MUCH ! YOU SAVED ME AN IMPORTANT BUSINESS OPPORTUNITY ! |
2 thankful Users |
