7/3/2024 2:20 PM | |
Joined: 8/12/2021 Last visit: 10/3/2024 Posts: 324 Rating: (30) |
Hi! First, I would try removing the Always true flag and manually triggering the request. It seems that the function is not executed. Make sure you are using the correct InterfaceID for your case. You can find more information and use cases at the following link
7/8/2024 10:52 AM | |
Joined: 8/3/2009 Last visit: 10/4/2024 Posts: 13851 Rating: (1747) |
Hello pencer check also this application example, perhaps there are some useful information: https://support.industry.siemens.com/cs/de/en/view/102020340 Bye Murof |
