4/5/2016 12:58 PM | |
Joined: 6/3/2014 Last visit: 1/17/2023 Posts: 660 Rating:
Hello Ale.Bon.ITA, the pictures you found in the library can best be changed by external programs (PS, Gimp, ...) outside TIA Portal. Here is a tool that can export graphics from the TIA portal:
If you want to use MS paint for the changes you don't need to export the graphic, you can use the "Edit graphic" function to open the graphic from inside the TIA Portal:
Last edited by: H.J. at: 4/5/2016 12:58:35 PM~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ★ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ |
5 thankful Users |
