7/22/2024 3:59 AM | |
Joined: 1/27/2009 Last visit: 8/27/2024 Posts: 172 Rating: (8) |
Hello Farzad.Soud, The short answer would be - because that's the way it is. Please investigate this Siemens manual entry Entry ID: 91696622? and read about force table and watch table. You will find out the differences and how to use them in proper way. In addition, if your input is connected directly to the output and you do not want to mess with force table, then you could simply add some memory bit in parallel and operate it. |
Last edited by: @rturas at: 07/22/2024 04:00:38typos The only thing necessary for the triumph of evil is for good men to do nothing |
