9/24/2013 11:05 AM | |
Joined: 11/23/2011 Last visit: 6/25/2024 Posts: 202 Rating: (32)
Hello simhan, I would recommend you to contact the Technical support for SIMATIC. Here is the link to the contact data: http://support.automation.siemens.com/WW/view/en/16605032 It would be also helpful to give to the Technical support also information about your "HW Config" and the "diagnostic buffer" (e.g. with screenshots). I hope this will help. Greetings, KM_AS |
9/25/2013 1:45 PM | |
Joined: 8/25/2005 Last visit: 7/5/2024 Posts: 1162 Rating: (110) |
Hello simhan, ok, it seems that a module of your slave was removed. So you got this information within the CPU. To find out which module it is you could try to open the hardwareconfiguration online an look at the diagnosic information of the slave. Maybe you could publish screenshots of the configuration? So we will have a look on it. Information about the OB 83 I found within the manual SIMATIC Programming with STEP 7 V5.5 Best regards Sabine AttachmentManual_STEP7_OB83.pdf (79 Downloads) |
