6/1/2015 5:53 AM | |
Posts: 14 Rating:
Thank you for your response. If you say that we need a block motor to start the pump? On which IOs should we connect it with the AO Block? |
6/1/2015 7:15 AM | |
Joined: 12/22/2014 Last visit: 10/7/2021 Posts: 173 Rating:
Hello ilyanorsaelehe94 You should use the APL block MotSpdCL. With this block you can automate a speed controlled motor and has all the IO for analog setpoints. |
Greetings |
