1/18/2018 7:01 PM | |
Posts: 2826 Rating:
Hello. The problem with following your instructions is that someone may fill in details that makes the system work and will not be able to tell you why. For example: having non optimized DB structures might help. I was hoping for demonstration projects. It was more difficult than what I thought. Find attach some code you can import into an S7-1500 project. Add the FC in OB1 to simulate. The simulation table (watch) is listed in an Excel sheet. Copy from blank cell A2 to I25. Paste into a clean watch table highlighting the first available cell. The code looks as follows:
The DBs "mem" and "ext" contains "data" :: array [0..9] of String[10]. You want something else. Without knowing how the structure look like it is hard to follow through. Consider sharing some demonstration project. Regards. Attachmentcode.zip (305 Downloads) |
