9/17/2024 1:38 AM | |
Joined: 3/22/2020 Last visit: 9/17/2024 Posts: 3 Rating: (0) |
Hi, the gsd data points generated from moxa gateway software are only readable on siemens? ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 09/17/2024 09:32:59New subject after splitting |
9/19/2024 11:51 AM | |
Joined: 8/3/2009 Last visit: 10/18/2024 Posts: 13982 Rating: (1760) |
Hello jonathan_92_b could you send us please a few more information about your question and the Devices and Versions you use in this case, also a network or connection chart would help to understand the communication better Bye Murof |
