9/4/2017 10:00 AM | |
Posts: 20 Rating:
Dear Expert My AOP30 starts but it shows "?????" please reply ASAP its an urgent. |
9/4/2017 10:09 AM | |
Joined: 5/12/2006 Last visit: 7/18/2024 Posts: 22318 Rating:
Hello, connection not correct or wrong FW Versions?
Christoph |
9/4/2017 10:18 AM | |
Posts: 20 Rating:
Sir, Earlier it was running healthier. |
8/26/2019 2:45 AM | |
Posts: 153 Rating:
Hello I think you already posted before this similar entry. Anyway try following: Change the RS232 CABLE/Change connector Check loose connection /Clean the control unit port. AOP port problem/CU Port problem (try to connect same AOP with different CU) Change firmware of Control unit /AOP |
8/27/2019 7:10 AM | |
Posts: 20 Rating:
Hello Mam, I have checked all except firmware upgrade.Please give a link to download firmware of AOP. In my existing system CU having Firmware 4743510 How to get new firmware of Control unit /AOP. |
5/4/2023 11:20 AM | |
Joined: 6/19/2017 Last visit: 6/28/2024 Posts: 8176 Rating:
New question published by AutoGen_4550988 is split to a separate thread with the subject AOP30 shows ????. Best regards |
