1/22/2024 8:22 AM | |
Joined: 3/14/2008 Last visit: 8/13/2024 Posts: 2084 Rating:
Hi, Can you give us more details? Did you migrate the version or just loaded V9.0 to V9.1 machine? In order to use an older library, you must install it on the new machine. |
1/22/2024 2:49 PM | |
Update the blocks from V9.0 to V9.1 and error should be gone. I assume its just a test project? Probably you did not install the libraries (APL and Basic Library) of V9.0 on the V9.1 |
Last edited by: Oreca at: 01/22/2024 15:04:46If I could help you, you can use the RATE button. Thank you. |
