11/10/2010 10:32 AM | |
Joined: 1/4/2007 Last visit: 9/2/2024 Posts: 1142 Rating: (175)
Hello Dilli, 1. At first I recommend you to do the adjustment correctly as described into the Quick Guide. (Please see the attached file, especially the pdf-pages 18 … 20.). Execute the adjustment commands during the belt is running! 2. You can steady the flow by changing the following parameters into Siwatool (DR3: index card “Filter”): - decrease the parameter “Limit freq. Hz” - increase the parameter “Depth of average value filter” Best regards Siwarexi AttachmentSIWAREX_FTC_B_Quick Guide_V3.1.pdf (179 Downloads) |
