7/22/2021 3:26 PM | |
Joined: 11/8/2018 Last visit: 7/24/2024 Posts: 85 Rating:
hi all, hope that you help me I am new in web server html coding, but I have managed to insert a number of buttons that with switch on and off certain inputs as the below: <form> <input type="submit" value="on Section9"> <input type="hidden" name='"Section9"' value="1"> </form> <form> <input type="submit" value="OFF Section9"> <input type="hidden" name='"Section9"' value="0"> </form> can you please guide me if I am on the right track and also if you can help me I wish to use 2 picture one is green and the other is red to show if output is on or off what would be the html code please thanks for your time Regards Mark ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 07/23/2021 07:56:50New subject after splitting |
7/31/2021 12:55 PM | |
Joined: 1/13/2021 Last visit: 4/5/2024 Posts: 64 Rating:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd"> <html> <!-- AWP_In_Variable Name='"Data_block_1".open' --> <head> </head> <body> <form method="post" action=""> <input type="submit" value="OpenValve"> <input type="hidden" name='"Data_block_1".open' size="20px" value="1"> </form> <form method="post" action=""> <input type="submit" value="CloseValve"> <input type="hidden" name='"Data_block_1".open' size="20px" value="0"> </form> <img src=":="Level":.png"> </body> </html>
Attachment20210731_152533.mpg (384 Downloads) |
7/31/2021 12:56 PM | |
8/3/2021 9:58 AM | |
Good morning thanks for you reply but i couldn't put in my coding. i have 2 tables one with the the switches and one with will show the input and outputs but couldn't get how i am going to including it as per below [snip]
AttachmentFiles.zip (371 Downloads) |
Last edited by: MPBusuttil at: 08/03/2021 10:00:45Last edited by: Jen_Moderator at: 08/03/2021 11:45:49Added code as txt file. Added all files as zip file. |
8/6/2021 1:10 PM | |
Good Morning, Please find attached the result I have got till now now the green and red i wish to alternate them according the output i have also attached the html file. I am using notepad++ Hope you can help me Regards Mark Paul Busuttil AttachmentNew folder.zip (338 Downloads) |
