2/8/2021 12:30 PM | |
Posts: 1 Rating: (0) |
Bonjour j'ai besoin de références pour la fourniture de licences logiciels (simatic wincc, librairie cemtec ...) et la configuration des PC industriels suivants: * IPC 547G (PC SERVEUR WinCC + STEP 7) 4GB RAM / RAID5 (3 X 1TB) Windows server 2008 R2 64bit préinstallé. * IPC 647D (PC SERVEUR PCS7) 8 Go de RAM / RAID1 1 To / serveur Windows 2008 R2 64 bits + PCS7 V8.1 préinstallé * IPC 647D (PC INGENIEUR PCS7) 8 Go de RAM / DD 1 To / Windows7 64 bits + PCS7 V8.1 préinstallé ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 02/08/2021 14:28:49New subject after splitting |
2/8/2021 3:26 PM | |
Joined: 9/27/2006 Last visit: 10/17/2024 Posts: 12289 Rating: (2687) |
Bonjour, La section internationale du forum de Siemens utilise l'anglais pour faciliter les échanges entre participants de nombreux pays. Veuillez nous écrire en anglais à votre prochaine visite. Merci. Hello, The international section of the Siemens forum uses English to make exchanges between participants from many countries easier. Please write to us in English on your next visit. Thank you. If you have purchased the Industrial PCs you described earlier with PCS 7 v8.1 pre-installed, you should have received basic licenses for the pre-installed core software, including Runtime POs. You can look at the screenshot below, extracted form this catalog: https://www.automation.siemens.com/w2/efiles/pcs7/pdf/76/stpcs7_201415_catalog_en_Web.pdf To be able to help you further, we need to know more details about the PCS 7 system you want to setup: for example will you have a server/client design, how many clients and will the servers be redundant, what add-ons Will you install for PCS 7/WinCC? You will also find in the abovevcatalog the license numbers for OS server and clients and optional add-ons, depending on your configuration choices. I cannot find references to the cemtec library in Siemens' SIOS, could it be that you are searching for CEMAT? In that case, this link might prove useful: - PCS 7 Minerals Automation Standard CEMAT V8.1 Released for Delivery https://support.industry.siemens.com/cs/ww/en/view/104982057 I suggest you contact your nearest Siemens distributor or rep to discuss the licenses you need, once the design of your PCS 7 installation has been almost finalized.. Use the catalog suggested to have a general idea of what is required for your application, have it confirmed or corrected from Siemens before you actually purchase. Hope this helps, Daniel Chartier |
