8/3/2021 3:37 PM | |
Joined: 1/15/2021 Last visit: 2/20/2024 Posts: 21 Rating:
Hi, your answer is perfect. But i met another question. for example, the attribute is an edit field. And, it has been linked to a standard table by using your vbs code. I need to display the attribute by default, and the value is the first description of standard table. ---------------------------------------------------------- Standard Table: Name Description Value1 Z010 kPa 0 Z020 mbar 1 ----------------------------------------------------------- I need the default display value in a text is the kPa in standard table. How can i make it by using script ?Thank you! ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 08/04/2021 08:11:51New subject after splitting New to comos, Stay hungry, Stay folish. |
8/4/2021 8:12 AM | |
Joined: 6/19/2017 Last visit: 6/28/2024 Posts: 8176 Rating:
Closed cause question posted twice. The second thread with the subject Using script to set text attribute.with a value from standard table is published within the conference Plant Engineering Software COMOS. Jen_Moderator |
