7/24/2021 10:44 PM | |
Joined: 10/11/2013 Last visit: 9/4/2024 Posts: 12 Rating:
Hi Priyanka, Could you connect NettoPLCSim and PLCSIM. I am facing similar problem. Earlier i had used NettoPlcsim it was working ok then. But with Ver 16 Tia Portal & PLCSIM V16 I am unable to use NetToPLCSIM. Basically I had observed PLCSIM is using "s7oiehsx64" services and Nettoplcsim-S7o-v-1-2-4-0 is using "s7oiehsx" services. I tried to stopping "s7oiehsx64" services then NettoPLCSIM is working (Get Port 102 -- OK, Start & Stop S7DOS help services. But My PLCSIM is stopping & not communicate with TIA. Same if I try to stop "s7oiehsx" NettoPLCSIM is not working & PLCSIM is working. have you got solution for this. If yes, can you please share it with me. Best Regards, Ravikiran R
Last edited by: Jen_Moderator at: 07/26/2021 11:28:54New subject after splitting |
7/26/2021 11:29 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating:
Closed cause question posted twice. The second thread with the subject NETTOPLCSIM Tia 16 is published within the conference Communication / Networks. Jen_Moderator |
