4/25/2012 8:55 AM | |
Joined: 8/27/2006 Last visit: 9/2/2024 Posts: 719 Rating: (88) |
Check Step7 Lite. It is free and downloadable from here: |
The more you know, The more you know that you don't know |
4/25/2012 9:08 AM | |
Joined: 4/19/2008 Last visit: 9/3/2024 Posts: 1525 Rating: (159) |
Hello Monal, The Basic Languages LAD, FBD, STL The SIMATIC Manager On Bottom you will find more Link for Other Demo Also, For Order a free Software You have to contact your Local Siemens, In Step7 Light all the Part is not cover which you mention. |
Ammy |
4/25/2012 9:30 AM | |
Posts: 133 Rating: (9) |
Also if you wish to receive formal training. Siemens SITRAIN offer very good training. http://sitrain.automation.siemens.com/sitrainworld/ You could attend PRO1 (Programming 1) I found it very informative. |
4/25/2012 11:09 AM | |
Joined: 9/6/2008 Last visit: 5/7/2022 Posts: 1121 Rating: (86) |
Hi Well you can use Step7 as other have said as it has all the advance features for learning. I would not recommend Step7 Lite for you. 1.You can also have MPI adapter so that communication is little easy as we have MPI/USB connector. 2. Step7 V 5.5 you can get 15 days trail DVD from your local siemens partner. When you install Step7 you will have documentation with it, so you can go through all the documents from. Please find the tips for STL programming. AttachmentSTL-cheat-sheet-by-alphabet.pdf (267 Downloads) |
Jazz |
4/29/2012 10:00 AM | |
Have a look on the Following Link... What are the essential differences between STEP 7 Lite and STEP 7 / STEP 7 Professional? You can used PLC SIM with Extra License,as per above link. |
Ammy |
