11/15/2023 12:37 PM | |
Joined: 11/14/2023 Last visit: 2/27/2024 Posts: 3 Rating:
Thanks for your message. I use the adapter in the USB port of my laptop. There is an ethernet port at the adapter which I connect with a cable to the PLC. (Hub used: A-KONIC USB C HUB 8 in 1) In the device manager I see as shown in the screenshot. in the map Oline Accesses I see as shown in the screenshot. Should I use S7USB or PN/IE as interface? (I'm a *** on PC's so not sure if I show you what you need.) Kind regads. |
8/14/2024 1:50 AM | |
Joined: 8/14/2024 Last visit: 8/23/2024 Posts: 2 Rating:
HI MAN, DID YOU GET ANY SOLUTION FOR THIS ISSUE, PLEASE LET ME KNOW, I AM FACING SAME ISSUE. |
