11/24/2022 11:42 AM | |
Joined: 6/7/2022 Last visit: 10/11/2024 Posts: 9 Rating: (0) |
Hi Yansopi, I have the same problem between the Server and the Client. We upgrade the computer (not the software) we bought a new computer from Siemens Series IPC J and we configğred for the plant. Then we completed commissioning completed for all connections and screens but we can't complete Data monitoring. There is a screen where we see "No connection to server", also when we close Wincc on the server that message has been changed ( server not working ....). Now we need a solution but I tried all the document solutions. Also, there is haven't Simatic shell on the client.. Thanks for your answer ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/25/2022 08:11:07New subject after splitting |
12/6/2022 10:43 AM | |
Joined: 8/3/2009 Last visit: 11/19/2024 Posts: 14194 Rating: (1775)
Hello check if you have acivated the remote communication on the Server: https://support.industry.siemens.com/cs/ww/en/view/109769234 Bye Murof |
Last edited by: Murof at: 12/06/2022 10:43:28If this Information really helps, you could use the Rate function |
