4/25/2024 7:33 AM | |
Joined: 8/3/2009 Last visit: 8/8/2024 Posts: 13502 Rating:
Hello Edmilson8 Do you use the latest Update for your V7.5 SP2? https://support.industry.siemens.com/cs/de/en/view/109793460 Check this FAQ for general configuration of all your WinCC stations: https://support.industry.siemens.com/cs/de/en/view/868014 https://support.industry.siemens.com/cs/ww/en/view/22132850 Do you use the same network/networkcard for terminal bus and machine bus (connection to the PLCs and periphery)? Bye Murof |
