7/5/2011 1:14 PM | |
Posts: 118 Rating:
Hi Darius, can u give me some more details about Node failure after Y-Link? now i am in need of getting all node failure of slaves connected behind Y-Link. I am using SFC13 for Single PLC system. Its working fine. When i use SFC13 for Hot backup PLC (with Y Link), i am not able to read the node failure status of slaves after Y-Link attached is the Hardware configuration. Splitted from DP diagnostic on S7-400. AttachmentDoc1.pdf (127 Downloads) |
7/5/2011 1:40 PM | |
Joined: 4/24/2009 Last visit: 8/20/2024 Posts: 2682 Rating:
Thread closed, because question is already published in the following thread I have DP/DP Coupler and ASi Master connected behind the Y- Link and need to display the node failure of all ASi Slaves. Best regards O_Moderator |
