11/16/2017 3:41 AM | |
Posts: 40 Rating:
Hello, As you suggested, the IOT2040 can ping to a web site. Howerver, I still have the problem above when run "npm install node-red-contrib-modbus" at directory "/usr/lib/node_modules". [snip] Q2: which command should I use to install the package ? Thanks. ------------------------------------------------------------------------------------------ |
Last edited by: eric00058 at: 11/16/2017 3:42:09 AMLast edited by: Jen_Moderator at: 11/16/2017 12:29:04 PMNew subject after splitting and deleted 1st question. |
7/17/2018 2:02 PM | |
Posts: 5 Rating:
Hey Did you succeed in installing the packages without an internet connection? Kind regards |
