11/24/2017 1:47 AM | |
Posts: 40 Rating:
Hi, Please help to give some advice on node-red-dashboard. 1. ui_text_input widget is used for text input. Is it possible to used for data input ? I tried to input data, but it seemed that the widget cannot identify the input. Do you have any example on its usage ? Thanks in advance. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/24/2017 12:19:27 PMNew subject after splitting |
11/24/2017 1:41 PM | |
Posts: 439 Rating:
Hello, Why do you want to use the "ui_text_input" for data when there is a "ui_numeric" just above it? Best regards, Hugo |
