4/15/2019 7:35 AM | |
Joined: 4/28/2015 Last visit: 6/3/2024 Posts: 3345 Rating:
Hi, why can't you upgrade to 2.2? You can download the image here. You mention /usr/lib/node_modules/node-red/node_modules/node-red-contrib-IoT2000-gpiov2/, these are the latest nodes. Did you download them from here? There are some problems with mraa, but in this version of the nodes the have been solved. Best regards! |
Not working for IOT2050 support anymore from March 1st, 2024. |
4/15/2019 10:27 AM | |
Posts: 15 Rating:
Because the 2.2.0 image is not compatible with "MindConnect 2040". ;) You know...
As I found out, there are 3 modules for a similar task:
My installation in /usr/lib/node-modules/ is:
Best Regards! P.S. Maybe at any time there will be an image update, which also works with the "Mindconnect 2040". Is the hardware really such different? |
4/17/2019 4:00 PM | |
Posts: 15 Rating:
Then, let's wait for 2.4.0. ;) |
