5/2/2017 5:22 AM | |
Joined: 2/20/2014 Last visit: 6/11/2024 Posts: 396 Rating:
Hi, i have successfully installed the node-red. I am having problem on reading the changes to the PLC. I am not able to see any updates to the file. Can anyone advise me on how to get this? I have followed all the steps. But when i key in "cat filename", i am not getting changes to the tags that i had placed in node-red webserver. I have attached a screenshot here for your reference. Thank you in advance.
Last edited by: Min_Moderator at: 5/3/2017 3:54:02 PMNew subject after splitting |
5/2/2017 8:18 AM | |
Posts: 215 Rating:
Have you checked the box "Create directory if it doesn't exists"? It should be in the file node and it should be checked! |
5/3/2017 2:45 AM | |
Hi, i have attached the config file here. Yes i am able to ping the PLC after login to IOT using putty.
Attachmentnode config.txt (427 Downloads) |
