8/12/2013 5:14 PM | |
Joined: 9/27/2006 Last visit: 7/11/2024 Posts: 12268 Rating:
Hello adam; This might not directly answer your question, but if you search for analog input/output grounding issuesusing the Search box at the right of this page you will find many threads on such problems, and you will see many examples of the type of problem erroneous connections of Analog inputs and outputs can be experienced in the field. In their manuals Siemens prefers to give recommendations on wiring and proper grounding that would tend to eliminate these problems, rather than describing allissues. See the attached document, taken from the following manual: SIMATIC S7-300 S7-300 Module data Hope this helps, Daniel Chartier |
