10/17/2017 11:01 AM | |
Posts: 28 Rating: (0) |
Hello, I need support for Set PG/PC interface setting. I've set 'Ethernet connection (Auto)' in set PG/PC connection. But I'm not getting desired PLCs when I try to browse trough 'Edit Ethernet node' option from simatic. therefore PC can not communicate with PLC. With the same setting other PC is able to communicate with PLC Kindly assist why this is happening & how can it be fix. Regards, Manoj ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/18/2017 9:05:28 AMNew subject after splitting |
10/17/2017 12:06 PM | |
Joined: 5/12/2006 Last visit: 11/18/2024 Posts: 22452 Rating: (3030)
diesable Firewall, disable antivirus protection |
