6/21/2024 6:38 AM | |
Joined: 3/7/2016 Last visit: 6/27/2024 Posts: 3 Rating:
Hi Big John Thanks for the suggested solution. At one of the customer power station, we are trying to time synch the auto synchronizer relay (Type 7VE61). While doing the same we added the NTP master to the IEC station and assigned the IP address to it. We also assigned "Ethernet NTP" as the time synchronization method under the "Time synchronization & Time Format" setting of the relay, but we are still getting the "NS ER" error on the Relay display. can you please suggest for the possible error cause and the remedial solution. I have also attached the captured photographs of the error and the setting in the relay. ------------------------------------------------------------------------------------------ AttachmentSetting and Time Sync Error Dispaly 7VE61.zip (8 Downloads) |
Last edited by: Jen_Moderator at: 06/21/2024 10:57:30New subject after splitting |
