1/4/2009 11:52 AM | |
Joined: 3/21/2006 Last visit: 7/26/2024 Posts: 10228 Rating:
Hello ntban, For sure you must contact with nearest Siemens seller in your place for more deails but: In orders for OCM III ( 7ML1002-0DA05 ) you can assigned that want to received with temperature sensor TS2 ( 7ML1812-.... ) . 7ML1106-.....-.. Order Nr for XRS-5 Transducer Also order separately. regards |
1/5/2009 9:19 PM | |
Posts: 151 Rating:
Hi ntban, yes, for optimal accuracy you need the TS-2 (and you do want optimum accuracy, otherwise you would have chosen a multiranger 200 for OCM The OCM-III will not use the temperature sensor in the XRS-5 sensor, that's why. Here you can find the manual: http://support.automation.siemens.com/WW/view/en/30088468 Best Regards, SonicRanger. |
