10/9/2012 10:08 AM | |
Posts: 18 Rating: (0) |
Good day, All! Is it possible to upgrade the rack of CPU 416-2 DP6 ES7 416-2XK00-0AB0 with new CP443-1? Will it work? |
10/9/2012 11:06 AM | |
Joined: 4/22/2010 Last visit: 2/15/2024 Posts: 5697 Rating: (713)
Hello, Had some cases and they all ended with new CPU. Found a document for you that could answer your question: What should you watch out for when upgrading from previous modules to the successor module CP443-1 or CP443-1 Advanced? Regards, Marcjan |
Problem solved? |
10/9/2012 12:34 PM | |
I see. So, than the next question is how new processor behave himself with the old ET200M? Is that so we have to change all DCS? |
10/9/2012 12:59 PM | |
It's a pity. Because the problem is greater than just simple upgrade. There is PCS7 v5.0 And it has to be changed because of problem with old PC. After your answer I described my task |
10/9/2012 2:48 PM | |
Hello, I still believe this is a task for Siemens Rep. in your country, let them advise to solve this problem. Regards, Marcjan |
Problem solved? |
