1/30/2024 8:42 AM | |
Joined: 5/12/2006 Last visit: 7/24/2024 Posts: 22324 Rating:
direct connected to the plc or do you use some switches/Routers? |
1/30/2024 8:48 AM | |
test it first without the switches if this work |
3/1/2024 10:36 AM | |
Joined: 8/3/2009 Last visit: 7/24/2024 Posts: 13350 Rating:
Hello steven.noppe If you simulate then there could be also an issue with the Set PGPC Interface and the Accesspoint in your connection: https://support.industry.siemens.com/cs/de/en/view/109748099 If you cannot get it work with the tips from this forum you can also try to contact Siemens Support. Bye Murof |
