8/7/2018 10:11 AM | |
Joined: 10/18/2012 Last visit: 12/15/2023 Posts: 225 Rating:
Hi IC Justi, First of all: ensure, that the input via touch is working (does your mouse cursor move via Touch?). If you have a multitouch display and Windows 10 embedded, than you may run into some issues. If no touch works at all, you probably must switch the display to singletouch-mode. If your touch generally works with Windows 10, then there are some ways to show the keyboard. You check this page: regards, |
